• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Re: Move/Rotate entire drawing
    02-15-2012 12:49 PM in reply to: glen.cameron
    If you need to maintain the connection to the FBK's, someone else will have to jump in here. If not, you could just explode the figures to 3dpolys and move them.
    Jeff_M, also a frequent Swamper
    Please use plain text.
    Active Contributor
    02-15-2012 12:54 PM in reply to: Jeff_M
    Thank you for your time and words of wisdom.
    I would prefer to maintain the figures, so I hope someone else may have another suggestion or two to try. :smileyhappy:
    Glen W. Cameron, C.E.T.
    Engineering Technician 1
    City of North Bay
    North Bay, Ontario, Canada
    Valued Contributor
    02-15-2012 02:15 PM in reply to: Jeff_M
    can you extract the figures thru the xref using the copy nested objects command onces you have the old drawing aligned with the new base drawing?
    Tony
    CAD Manager
    www.tonyscivil3dworld.blogspot.com
    Member
    davehi
    02-15-2012 06:16 PM in reply to: glen.cameron
    Have you tried using the Translate Database command?
    You can use it to move alll the data in the suvey database to a new location.
    DaveH
    Dave Hill
    *Expert Elite*
    Neilw
    02-15-2012 07:57 PM in reply to: davehi
    I'm not an expert on the Survey Database but it is my understanding that one of the strengths of the survey database is the ability to reproject the survey to other coordinate systems. Thus you should be able specify the transformation parameters to project your local survey to a UTM.
    Richard Sincovec (sinc) can probably help with the workflow. You might try giving him a ping.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Active Member
    12-17-2012 08:07 AM in reply to: glen.cameron
    This is the issue I cannot find a solution to.  How do you "unlock the survey database?"  I have read many people say that's what needs to be dont to rotate or edit survey points but then I haven't seen anyone actually explain how to do it.  The closest I got was "Prospector-Settings-Point-(right click)-Edit Feature Settings-Update Points-'Allow Checked In Points to be Modified'-True"  except then the points still won't rotate.
    Any ideas?  I'm trying to rotate a preliminary survey about a point a certain number of degrees to match existing survey data.  Everything in the drawing rotated except the survey points....
    Member
    davehi
    12-20-2012 04:09 AM in reply to: fordtruckman
    Give this method a try if you wish to adjust the Survey Database.
    From the Survey Toolspace open the Survey Database you want to edit.
    From the Survey Ribbon choose the "Modify" band from the Modify panel.
    Pick Translate database
    (you could also enter "Translatesvdatabase" at the command line to run it)
    The Translate Survey Database dialogue box will open and then you can set your basepoint, rotation angles, etc. which will move the entire database to the new location.
    Import the points from the surveydatabse as usual.
    Dave Hill
