AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Move/Rotat e entire drawing
- Highlight
- Email to a Friend
If you need to maintain the connection to the FBK's, someone else will have to jump in here. If not, you could just explode the figures to 3dpolys and move them.
- Highlight
- Email to a Friend
Thank you for your time and words of wisdom.
I would prefer to maintain the figures, so I hope someone else may have another suggestion or two to try. ![]()
Engineering Technician 1
City of North Bay
North Bay, Ontario, Canada
- Highlight
- Email to a Friend
can you extract the figures thru the xref using the copy nested objects command onces you have the old drawing aligned with the new base drawing?
Tony
CAD Manager
- Highlight
- Email to a Friend
Have you tried using the Translate Database command?
You can use it to move alll the data in the suvey database to a new location.
DaveH
- Highlight
- Email to a Friend
I'm not an expert on the Survey Database but it is my understanding that one of the strengths of the survey database is the ability to reproject the survey to other coordinate systems. Thus you should be able specify the transformation parameters to project your local survey to a UTM.
Richard Sincovec (sinc) can probably help with the workflow. You might try giving him a ping.
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
- Highlight
- Email to a Friend
This is the issue I cannot find a solution to. How do you "unlock the survey database?" I have read many people say that's what needs to be dont to rotate or edit survey points but then I haven't seen anyone actually explain how to do it. The closest I got was "Prospector-Settings-Point-(right click)-Edit Feature Settings-Update Points-'Allow Checked In Points to be Modified'-True" except then the points still won't rotate.
Any ideas? I'm trying to rotate a preliminary survey about a point a certain number of degrees to match existing survey data. Everything in the drawing rotated except the survey points....
- Highlight
- Email to a Friend
Give this method a try if you wish to adjust the Survey Database.
From the Survey Toolspace open the Survey Database you want to edit.
From the Survey Ribbon choose the "Modify" band from the Modify panel.
Pick Translate database
(you could also enter "Translatesvdatabase" at the command line to run it)
The Translate Survey Database dialogue box will open and then you can set your basepoint, rotation angles, etc. which will move the entire database to the new location.
Import the points from the surveydatabse as usual.
