• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    silvernich
    Modelspace layer control per viewports
    296 Views, 4 Replies
    11-19-2012 03:25 PM
    Hello all,
    Is there an easy way to switch from a viewport in paperspace to modelspace and have the same layer state show up? I typically run with my paperspace set up with the layers showing how they will print (show lightweights and display plot styles) but I would like to be able to switch to model space and only see the layers that are showing in a particular viewport, to minimize manual layer isolation.
    I used to know a way to do this.
    P.S. I am using C3D 2011.
    Civil 3D 2011/2013 User
    Please use plain text.
    AllenJessup
    Re: Modelspace layer control per viewports
    11-20-2012 06:06 AM in reply to: silvernich
    Allen
    11-20-2012 10:08 AM in reply to: silvernich
    Or you could save a Layer State in the viewport, or save a View with layer snapshot in the viewport, and restore it in the model tab.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    silvernich
    11-20-2012 11:24 AM in reply to: AllenJessup
    Allen,
    This is exactly what I wanted. Thank you. Perhaps the name should not be "maximize viewport" as this bottom really does more than that.
    - Nich
    AllenJessup
    11-20-2012 11:31 AM in reply to: silvernich
    Nich
    Mine is not to reason why. Mine is to remember esoteric commands and system variables.
    Allen
