AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm labeling using Mleader style but the text is not showing the way I want it (See pic attached).
I want the text to look like when I use qleader. I normally draw the leader using qleader with no text, then I manually add the text since always does not show the way I want it. The reason that I want to have it this way since we do the drawing at X scale then Eng. Dept. do theirs at Y scale and all the text with leader are way far apart.
Neptuno8881
Re: Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So by default, the text is coming in on an angle...and you want it at zero deg?
Are you in WCS?
In MS?
In PS?
MS through a viewport?
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
Re: Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
See attached to correct the text orientation in your Mleader Style.
C3D 2012 SP3
Win 7 Professional 64 Bit
Re: Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have my drawing ucs set to WORLD, and dview 17 degree on Model and Paper space. What I would like is to have it to read horizontal all the time regardless of the dview angle.
Thanks.
Neptuono8881
Re: Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I did that already and still does it.
Thanks.
Neptuno8881
Re: Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If your placing these labels in Layout and the text is an annotative style & Match text orientation to layout is checked it will be horizontal.
If in model space, I'm not aware of a setting to accomplish what your after.
C3D 2012 SP3
Re: Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I guess mleader does not work well since it's holding true North and I'm labeling in MS when the dwg. is dviewed.
I guess my best option is changing manually the degree angle in the properties box to make it work.
Neptuno8881
Thanks.
Re: Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Neptuno8881 wrote:I'm labeling using Mleader style but the text is not showing the way I want it (See pic attached).
Neptuno8881
I've had the same issue happen whenever I use DVIEW and leaders. I never use DVIEW because of this. If you use UCS>3 POINT>NEW then PLAN in your viewport you don't have to worry about the leaders not being horizontal. The other option is to use a C3D Note object. It'll always rotate and is annotative.
Civil 3D 2014 x64
Windows 7 64-bit
6GB RAM
Re: Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Land Consultants
Civil3D 2012 (Service Pack 2.1)
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Re: Mleader Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That really works.
Neptuno8881
