• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    ivars.kajins
    Missing data from profile view vertical geometry data bands
    253 Views, 4 Replies
    09-09-2011 05:50 AM
    Hello, i have created a data band in profile view that should show a created profiles elevation, but some of the the data fields are missing irregulary. Also in the data band that shoud show the diferenece betven the tow profiles - EG and the new profile the data is missing. The EG profiles data and the surface are ok all is shown. What could be the problem ?
    Please use plain text.
    *Expert Elite*
    Re: Missing data from profile view vertical geometry data bands
    09-09-2011 06:57 AM in reply to: ivars.kajins
    New Member
    ivars.kajins
    09-09-2011 07:12 AM in reply to: wfberry
    Running Autocad Civil 3D 2012 , on Windows 7 Enterprise X64
    Distinguished Contributor
    11-10-2012 02:25 AM in reply to: ivars.kajins
    Hi
    Could anyone offer a suggestion to this issue. I have exactly the same problem where a profile (created by a surface) is missing data where there is definately data. Most of the data is there it is just one or two stations which have not populated with elevations at those points. Not that i needed to but I checked there is a surface elevation there by running the inquiry profile tool for those stations missing data. So why would they not populate?
    Cheers
    Ben
    c3d 2013
    xp
    Valued Mentor
    11-12-2012 06:17 AM in reply to: Bennos1
    Which surfaces are you targeting in the band settings? Check the text value for surface definition as I sometimes use surface 1 to control level markers where surface 1 gradebreaks are.
