• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Material wise volume reports
    98 Views, 2 Replies
    10-09-2012 03:33 AM
    Herewith i we enclosing corridor cross Section image . we need to know that material wise QTY Report Creating Steps
    in civil 3d.pls update as earliest possible.
    Thanks & regards
    Jagadeesan.G
    jagadeesan@usam.in
    Please use plain text.
    Re: Material wise volume reports
    10-09-2012 09:31 AM in reply to: g_jaga1975
    1. Create Sample Lines
    2. Create Material List
    3. Run Volume Report
    See the Civil 3D tutorial called Calculating Earthwork Volumes from Corridor Models
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    neilyj
    10-09-2012 12:44 PM in reply to: g_jaga1975
    That's some corridor section...!!!
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
