AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Masked area on clipped sheets
- Highlight
- Email to a Friend
- Report Inappropriate Content
On the side of sheets created with the Create Sheets command there is a grey area that masks out the referenced files at the match line. Is there a way to reproduce this without having View Frames and using the Create Sheets? In other words, I a manually creating these plan sheets and I wonder if there is a better way of masking than using wipeout on the sheet tabs.
Nvidia GeForce GTS 450
8 GB Ram
Intel Core i5-2310 @ 2.90 GHz
v. F.107.0.0 AutoCAD Civil 3D 2012 SP1
Re: Masked area on clipped sheets
- Highlight
- Email to a Friend
The other way would be to use a Polygonal Vewport that cuts the view off at the match line. This eliminates the need for wipeouts.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Highlight
- Email to a Friend
Basically, all the match line is doing is placing a solid hatch in the drawing. If you want to replicate it, just do that. You'll need to make sure you put them on appropriate layers and freeze/thaw in the appropriate viewports.
- Highlight
- Email to a Friend
So, a solid hatch that prints white?
8 GB Ram
