• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Re: Mark items in alignment view to display in profile view...
    01-11-2013 10:15 AM in reply to: Postmaster_G
    I edited my acad.pgp file to make the keyboard shortcut POP for the command PROJECTOBJECTSTOPROF
    That way I can select the objects first, then run the command.  (You can do they by typing the whole command too, but I like my shortcuts.)
    You can use quick select or a right-click 'Select Similar', or anything else you fancy.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    Active Contributor
    Postmaster_G
    01-11-2013 10:36 AM in reply to: troma
    Now that is a great suggestion!!  I changed my alias just as you had and it works great.
    "POP" IS a great alias for this one :smileyhappy:
    Active Contributor
    Postmaster_G
    01-15-2013 06:07 PM in reply to: dgordon
    A lot of the items are just line work where the object type is assumed or called out (sizes etc.)
