• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    skintsubby
    Accepted Solution
    Manually Adding a Station
    92 Views, 3 Replies
    05-04-2012 12:36 AM
    I've been trying for a while now and I'm hoping someone can show me where I'm going wrong..
    All I want is to manually add a station in between to other stations.... ie I can produce this-->
    However I would prefer to produce this -->
    Which has an additional station added as required from time to time.
    Thanks for reading.
    Please use plain text.
    Distinguished Mentor
    Re: Manually Adding a Station
    05-04-2012 06:12 AM in reply to: skintsubby
    You can manually add extra stations such as you want with station equations in the alignment properties.
    To get the stations to be labeled, you need to have a station equation label in the alignment label set.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    *Expert Elite*
    05-04-2012 07:19 AM in reply to: skintsubby
    What about a simple station-offset label?
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    skintsubby
    05-07-2012 10:15 PM in reply to: andrewpuller3811
    Thanks Andrew.... and Matt.
    I just needed a pointer in the correct direction. I've now got it working how I want it
    Mark
