• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    AllenJessup
    Make text slide along a polyline
    373 Views, 17 Replies
    01-24-2013 01:15 PM
    About 6 years ago some people in the Land Desktop group were complaining about not being able to move the text in a linetype so as not to obscure other entities. Peter Funk gave me some suggestions that I've finally tried to figure out. <origianl post>
    I'm attaching a document that explains how I went about it and a drawing showing an example. Drawing is 2012.
    I don't say this is going to replace linetype. I'm also going to see if there's a better way of doing this with Civil Objects. But I've wanted to figure this out for a while and had some down time today. So this is for you to play with if you want. I was looking at my Undocumented Commands file and that reminded me of it since this done with un(or little)documented commands.
    If you open the drawing. Select one of the magenta circles (nodes) in the center of the text to activate grips. Select a triangular grip and use it to slide the text along the polyline.
    Please use plain text.
    *Expert Elite*
    Re: Make text slide along a polyline
    01-24-2013 01:44 PM in reply to: AllenJessup
    Thanks, Allen. What a nice gift for all of us Civil 3D nerds here!
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    neilyj
    01-25-2013 12:12 AM in reply to: tcorey
    Great tip - I wouldn't have figured that one out in a month of Sundays...!!!
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    *Expert Elite*
    Joe-Bouza
    01-25-2013 05:08 AM in reply to: AllenJessup
    Thats a good one Allen. I need to study a bit.
    I make c3d line curve styles with text like 8"W and add multi segments. If I need more I copy in place ans slide to position and if I need less I delete as needed.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    AllenJessup
    01-25-2013 05:38 AM in reply to: neilyj
    It obviously took me longer than that. I wasn't working on it all the time of course. :smileyhappy:
    *Expert Elite*
    AllenJessup
    01-25-2013 05:40 AM in reply to: Joe-Bouza
    Yeah! As I said, there's probably a better way to do it with Civil Labels. That's my next step. I just wanted to put DONE on this one.
    *Expert Elite*
    AllenJessup
    01-25-2013 05:43 AM in reply to: tcorey
    Believe it or not. When I tried to explain the EE program to one of our Engineers and mentioned that there are only 64 right now. He said "That's because no one else will admit to being that big of a computer nerd".
    *Expert Elite*
    AllenJessup
    01-25-2013 07:21 AM in reply to: Joe-Bouza
    Joe,
    Are you creating a bunch of segments in the polyline to get multiple instance of the text or do you just rely on copy. Is there maybe a method of putting multiple labels on one segment that I've missed?
    dseatter
    01-25-2013 10:10 AM in reply to: AllenJessup
    Allen,
    Thanks for sharing. Works great.
    I will be using this technique for PADOT work.
    I have been struggling with required spacing and visibility for my utility lines
    and this should really help.
    Dave Seatter, PLS
    C3D 2013 SP1
    Win 7 x64 Pro SP1 - 12.0 GB RAM
    Intel Xeon W3530@2.8 GHz - ATI FirePro 4800
    Dell T3500
    *Expert Elite*
    01-25-2013 10:19 AM in reply to: AllenJessup
    Well, just clicking on the polyline will add the labels a second time.  But they'll be on top of each other, in the middle of each segment, not nicely spaced out along the line.  This avoids using the copy command, but doesn't really get you where you're trying to go.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
