• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    tmcmannis
    Accepted Solution
    MTEXT Rotated 90 in Model Space when set to Match Layout
    334 Views, 17 Replies
    01-03-2013 08:30 AM
    Hi everyone. This is driving me crazy right now. I have a drawing I am working on regardless of whether I use DVIEW Twist or UCS rotate I encounter the same issue. I start with MTEXT that is parallel to my intended view. However, as soon as I make it annotative and set it to Match Layout the text rotates 90-degrees and is no longer plan readable.The text lives in model space, not paper space. I've even roated the layout viewports in this specific drawing to match, and the text appears correct when viewed through a viewport, but when I jump back to model it is turned on end 90-degrees again! Have I missed  a setting somewhere? Shouldnt the text reamin oriented with current view in model space? Thanks anyone who can help!
    I am uploading a link to a video which shows this problem in detail.
    http://screencast.com/t/L8yawl1AqVeP
    -Tristan
    Please use plain text.
    *Pro
    Re: MTEXT Rotated 90 in Model Space when set to Match Layout
    01-03-2013 10:00 AM in reply to: tmcmannis
    You are using Civil 3D correct?  so why not use a C3D general note label in place of annotative mtext?
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Active Contributor
    tmcmannis
    01-03-2013 10:34 AM in reply to: dgordon
    Dan,
    I am on Civil 3D (2011). The reason I have not yet used a civil note is because I want to be able to control visibility of this label based on viewport scale. For instance, I do not want the label to show at 100 scale, but do want it on at 40 scale and 200 scale. I know I could create another layer, but thought I could handle this issue this way. It actually does work in the XREF'd sheets, but when I go back to the source drawing to edit the text and try to more accurately position the text, it is always turned 90 to my plan view which makes fine tuning the text position difficult.
    -Tristan
    *Pro
    01-03-2013 11:13 AM in reply to: tmcmannis
    how are you changing the mtext to annotative?   I used the properties box to change to a annotative style and then set my text height.   I then used dview twist and camera to make each viewport a 3d angle.   on the right click menu I don't see a command to match the text to the layout angle the annotative text automatically aligns itself with the view.
    I also tried the view cube to change the angle of my viewport and still cannot reproduce your problem with the text rotating 90 degrees.
    I'm using a viewport scaled to 40 scale and a viewport scaled to 200 scale and I did dview twist in both viewports and added annotative scales for each viewport size.   I still do not see any movement or rotation of my mtext in model space.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    *Pro
    01-03-2013 11:14 AM in reply to: dgordon
    on a side note I went back to C3D 2011 also to try this with same result.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Active Contributor
    tmcmannis
    01-03-2013 11:23 AM in reply to: dgordon
    Dan,
    Thanks for delving into this more deeply. I am creating my MTEXT in model space with my view in model space already rotated/oriented how I want it using either UCS rotate or DVIEW twist. I then use the property panel to make the specific instance of MTEXT annotative. From that same propertt panel I set the option MATCH ORIENTATION TO LAYOUT to YES. It's right when I set that option that the text re-orients itself 90-degrees, which is also coincidentally where north in UCS World is.
    When you created your text, did you do it through the viewports into model space, or did you do it right in the model tab, then jump over and create viewports?
    Thanks again!
    *Pro
    01-03-2013 11:31 AM in reply to: tmcmannis
    Ok,
    I looked at your video this time and noticed that the north in your view cube is rotated 90 degrees to the left.
    and when I set up my ucs and view cube the same as yours I got the same result.
    when you use the option to match the view layout your tieing the rotation of the text in with the view cube.
    turning the match  layout off allows manual rotation of the annotative text.   So the reason the text rotates 90 degrees is because your view is rotated 90 degrees in model space.   if you rotate the view cube 90 degrees clockwise then the text will look correct.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Active Contributor
    tmcmannis
    01-03-2013 11:34 AM in reply to: tmcmannis
    Dan,
    I just tried your process noted above, and the text looks fine in the viewport, but as soon as I jump back to the model tab it is again rotated 90-d relative to my model space view.
    Jus tto clarify, the way I have been setting up my text is as follows- please let me know if I have made a mistake somewhere that is causing this.
    1) I start with the survey file which is oriented to state grid.
    2) I rotate my ucs and my plan view to get the orientation most of my drawing sheets will have.
    3) I create my MTEXT labels in model space
    4) I set the properties of the MTEXT to be annotative and assign a scale. While still in the properties for the MTEXT I set the option of MATCH ORIENTATION TO LAYOUT to be YES. However, the text is now rotated to match the World UCS.
    5) I jump over to a layout tab (either local or XREF'd) and set the viewport to match was previously set for the model tab above. Everything looks fine at this point.
    6) I jump back to the model tab of the source drawing and the text is still oriented 90-degree to my plan view which is based on a roated UCS.
    As mentioned previously, I have tried this using the older DVIEW twist method and get the same result where the text looks fine when viewed through a viewport, but is not consistent when I jump back into model.
    Hope this helps to shed some light on what I've been doing. Out of curiosity were you able to view the video I posted a link of? Thanks.
    Active Contributor
    tmcmannis
    01-03-2013 11:38 AM in reply to: dgordon
    Dan,
    I tried rotating the viewcube as you suggested, but my whole view rotates with it...so Im no longer looking at my model space as it is viewed from my sheet layouts. Is this what you meant when you said to rotate the viewcube clockwise? I really want to be able to keep my current view orientation shown in the video and have the text match that, and the viewports. I may be losing my mind, but I thought back in 2010 I was able to do this...
    *Pro
    01-03-2013 11:48 AM in reply to: tmcmannis
    this is where things are going south on you.
    by rotating the plan view 90 degrees to the right any mtext that is annotative and has the setting to match layout view will align itself with the modelspace view angle and not the ucs.   Your model tab layout view is not tied to north being up like it is when inside a viewport.   In model tab a layout can apparently be turned any which way.
    I hope i'm explaining this better this time.   It's not a bug it's the intended behavior.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
