• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Joe-Bouza
    Re: MTEXT Field data location
    10-19-2012 02:26 PM in reply to: atklump
    Does it matter? My first response is correct; there is no way (with out programing) to get c3d info int a field.
    Cut and paste, but that would be double posting a double post :smileysurprised:
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Please use plain text.
    *Expert Elite*
    10-20-2012 08:06 AM in reply to: atklump
    Deflections are included if you use an Alignment with your pipes.  It is under Label Styles, Tangent Intersection.
    Bill
    *Expert Elite*
    Joe-Bouza
    10-20-2012 12:31 PM in reply to: wfberry
    yes but you can't access it from the structure label style
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    11-02-2012 02:26 PM in reply to: Joe-Bouza
    Sorry Joe,
    No luck on the multiling labeling in GIS.  Our two GIS guys don't work with labels often enough to know.
    *Expert Elite*
    Joe-Bouza
    11-05-2012 05:51 AM in reply to: atklump
    Thanks for looking
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Employee
    11-05-2012 01:17 PM in reply to: Joe-Bouza
    Civil 3D doesn't have a pipe line / structure label like this of label built in.
    I would make two labels and place them on together. The structure label would label the size and number, and the aligment label would label the turned angle. I might add a short line seg to the "top" label so that I could snap the "bottom" label into position.
    Peter Funk
    Autodesk, Inc.
    Peter Funk
    Autodesk, Inc.
    *Expert Elite*
    Joe-Bouza
    11-05-2012 01:49 PM in reply to: peterfunkautodesk
    Thanks Peter
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    11-27-2012 02:02 PM in reply to: peterfunkautodesk
    Peter,
    It appears you are an employee of autodesk.  Could you find out why wouldn't autodesk have labels generated to function similar to mtext?  Be able to add fields to the labels, and make it annotative to improve efficiency of labeling?
    They made something that seems very robust, but if the general user can't figure it out intuitively, then it is relatively worthless.  Small companies can't afford the additional training required to optimize this stuff, especially when it can barely afford the subscription.
    The work around doesn't work when you have it oriented different in various viewports.
    Thanks for the suggestion though Peter.
    Adam
    Valued Mentor
    11-27-2012 05:05 PM in reply to: Joe-Bouza
    Joe,
    not sure if I completely grasped your question about multiline label (your question was on ArcGIS or Map 3D?), but are you trying to add labels composed of multiple lines pulling info from different attribute fields in ArcGIS? if so, you may be able to accomplish what you need with VB label expression using the  vbCrLf function. please see attached image for an example, labels the drainage area name, divides the sq.ft area by 43560, rounds it, and labels the arcreage in the second line.
    Civil 3D 2013 SP1, Win 7-64 bit
    12GB RAM
    *Expert Elite*
    Joe-Bouza
    11-27-2012 06:45 PM in reply to: Joe-Bouza
    Hi YoungPE,
    It the Mad3d I'm working in, I have since gotten into the expression builder, but in 2012 the enhanced label interface added a wizard that does do what I intuitivly expect it to do.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
