AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: MTEXT Field data location
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Does it matter? My first response is correct; there is no way (with out programing) to get c3d info int a field.
Cut and paste, but that would be double posting a double post ![]()
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Deflections are included if you use an Alignment with your pipes. It is under Label Styles, Tangent Intersection.
Bill
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
yes but you can't access it from the structure label style
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry Joe,
No luck on the multiling labeling in GIS. Our two GIS guys don't work with labels often enough to know.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for looking
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Civil 3D doesn't have a pipe line / structure label like this of label built in.
I would make two labels and place them on together. The structure label would label the size and number, and the aligment label would label the turned angle. I might add a short line seg to the "top" label so that I could snap the "bottom" label into position.
Peter Funk
Peter Funk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Peter
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Peter,
It appears you are an employee of autodesk. Could you find out why wouldn't autodesk have labels generated to function similar to mtext? Be able to add fields to the labels, and make it annotative to improve efficiency of labeling?
They made something that seems very robust, but if the general user can't figure it out intuitively, then it is relatively worthless. Small companies can't afford the additional training required to optimize this stuff, especially when it can barely afford the subscription.
The work around doesn't work when you have it oriented different in various viewports.
Thanks for the suggestion though Peter.
Adam
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Joe,
not sure if I completely grasped your question about multiline label (your question was on ArcGIS or Map 3D?), but are you trying to add labels composed of multiple lines pulling info from different attribute fields in ArcGIS? if so, you may be able to accomplish what you need with VB label expression using the vbCrLf function. please see attached image for an example, labels the drainage area name, divides the sq.ft area by 43560, rounds it, and labels the arcreage in the second line.
12GB RAM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi YoungPE,
It the Mad3d I'm working in, I have since gotten into the expression builder, but in 2012 the enhanced label interface added a wizard that does do what I intuitivly expect it to do.
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
