• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    MLeader Rotation in Rotated VPorts
    154 Views, 7 Replies
    11-28-2012 06:19 AM
    I have cut sheets following my alignment. I would like the mleaders I place in model space to be at zero rotation when I go to the individual sheets. Works fine for text if I check the "Match text orientation to Layout" box, but not for the mleaders. Is there a setting I am missing?
    Thanks in advance for any help....
    Please use plain text.
    *Expert Elite*
    Re: MLeader Rotation in Rotated VPorts
    11-28-2012 10:15 AM in reply to: dwk1204
    I see your question has not been answered. You might want to post this to the AutoCAD group as Mleader is a core AutoCAD feature not related to Civil 3D specifically.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Product Support
    Volker_C
    11-30-2012 03:07 PM in reply to: dwk1204
    Unfortunately at this time the "Match orientation to layout" property is only available for blocks and text objects with annotative scaling properties.
    Maybe someone here has a LISP or other work around available.
    Cheers,
    Volker
    Please let us know if your questions have been answered by selecting, "Accept as Solution"
    Volker Cocco
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    C3D_TomR
    11-30-2012 03:12 PM in reply to: dwk1204
    Create a named UCS based on the rotation of each sheet . Set that UCS current then type plan at the command line and enter twice. The drawing will zoom extents. Zoom back into the sheet extents and create a named view that matches the sheet name/number. Make sure the UCS is set to the appropriate sheet rotation (should default if it's the current UCS). Now switch between named views as needed to place mleaders at the proper rotation.
    *Expert Elite*
    Joe-Bouza
    11-30-2012 03:42 PM in reply to: dwk1204
    This is where I defend the use of a UCS
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Valued Contributor
    C3D_TomR
    11-30-2012 04:37 PM in reply to: Joe-Bouza
    As a Registered Professional Land Surveyor, I completely understand your concern about using a UCS other than World. I felt the same way for many years myself and I still cringe at the thought of newbies using a UCS. In this case, I purposely set the UCS so that 0,0 is at the bottom right corner of my sheet viewport extents. Since our drawings are typically in the TX83-CF (3 million, 10 million) coordinate system, we know right away if a drawing has a UCS set to something other than World when we xref it into a drawing.
    Another reason I'm more comfortable using a UCS other than world is because any coordinates annotated in the drawing are done through a Civil 3D label or note style, not AutoCAD.
    We also create a Named View called World that sets the view to the extents of the project and the UCS to World.
    DISCLAIMER: It is my personal opinion that using a UCS other than World is not the best solution for everyone, but it should be a consideration for this particular scenario.
    *Expert Elite*
    12-03-2012 01:46 PM in reply to: C3D_TomR
    Tom, those of us who do tech support for a living, sometimes, for expedience, tend to tell everyone, "Don't use UCS." It removes a big variable out of the support equation, makes our job easier, but I agree with you, when someone knows what they're doing, UCS us a wonderful tool. It's just so easy for a less experienced user to really mess things up ...
    Tim
    Tim Corey, Owner
    Redding, CA
    Valued Contributor
    C3D_TomR
    12-03-2012 02:10 PM in reply to: tcorey
    Alternate method:
    Draw an mleader in paperspace. Use chspace to send it to modelspace of the sheet. Switch to modelspace and select the automatically rotated and scaled mleader. Copy/paste to the original base file. Copy/paste this sample mleader to other locations in the drawing and edit the text and text location as needed.
