AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Lost Profiles on one Profile View
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a drawing with 13 profile views. 12 of them are working fine.
One profile view has 'lost' all its profiles. It should have one surface profile, and 6 superimposed profiles that are designed by layout in other profile views.
The profiles still show up in prospector and in the profile view properties, but you can't see them in the drawing. The profile view is on the same style as all the others, and the profiles are on multiple styles, but the same as their source profile and others in the drawing that are working fine.
I edited the alignment a little to see if that would 'jog the memory', then I turned all layers on and thawed. Still nothing. Then I superimposed a couple more profiles to see if they would show up. Again, they show in the properties, but do not plot in profile view.
I have a separate drawing with this alignment & profiles shortcut into it, and I'm seeing exactly the same behaviour there too.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
Re: Lost Profiles on one Profile View
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Perhaps your 32 bit and 4 GB ram are showing up.
Bill
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well, I won't say that's impossible (and I'd certainly love to have your spec's) but it doesn't feel like that. I would expect it to feel more buggy,crashes etc. The fact that the problem is replicated in another drawing suggests that there is actually something wrong with the data.
I rebooted and tried a recover, but no help.
Thanks for your suggestions, got any more?
If I cleaned up the drawing would someone be willing to look at it? I have to think about how much I can include and delete.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sure send it to me.
wfberry at bellsouth dot net
Bill
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Purged, deleted anything incriminating ![]()
Got it down from 98MB to just over 1MB.
Since I went to the bother of cleaning it up so much I thought I'd post it here rather than email; more than one person can have a chance to look it over, if they're so inclined.
Thanks to all that do!
*Edit*
I should have made it clearer in the drawing where the problem is. The long profile view to the south should have all the design profiles from the other two views projected into it. (I ended up deleting the surface in the cleanup, otherwise it should have its own surface profile in there too.)
Drawing is in 2011.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Something is buggared up with the alignment. It shows the starting station is 0+700 at 0,0, and shows the ending station of 0+700, yet it has a length of 1438.617. Thus far I haven't figured out what is going on.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Where are you looking to find the information that it starts at 0,0?
You're right though, it's a mess. Won't display the labels or let me add a station label either.
Just FYI: I set the reference station as 0+700 to match the stations on the other street.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
And it won't let me change it (I can go select a point but it remains set at 0,0)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Doh! That's where the x, y, coordinate is. (I knew that!)
I have no idea what happened, but I'm starting to think I should just explode it to a polyline and use that to recreate the alignment. This one is looking like a lost cause.
There's no rush on it right now, so I'll hold off on that to see if anyone has a better suggestion. Thanks!
