AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Lossing my contours in Civil3D 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi:
I have build a surface definded by polylines but time to time I lose the contours generated by the surface. I lost them when I re-open the file after closing it the day before or in other commands like save. I am Windows 7 user, 64 bit so I am not sure if some one else have had this problem. Maybe I have to check my RAM perhaps?
Thanks in advance
Rafael
Re: Lossing my contours in Civil3D 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you have Level of Detail switched on?
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi:
Thanks for the answer. I do not what is level of detail so I am not sure if I have it turned on or off. However I think that it is not the problem due I lose contourse for one of the surfaces that I have in the screen. The other one that defines my dams are intact
Rafael
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Level of Detail can be found HERE.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you see this,
then it is switched on; if not, then post the dwg
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi:
Thanks for the instruction. I am keeping my contours by now. I hope to follow up just in case I have this problem again. The lavel of detail commna is working by now.
Cheers
Rafael
