• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    Lossing my contours in Civil3D 2013
    207 Views, 5 Replies
    12-18-2012 01:51 PM
    Hi:
    I have build a surface definded by polylines but time to time I lose the contours generated by the surface. I lost them when I re-open the file after closing it the day before or in other commands like save. I am Windows 7 user, 64 bit so I am not sure if some one else have had this problem. Maybe I have to check my RAM perhaps?
    Thanks in advance
    Rafael
    Please use plain text.
    *Expert Elite*
    neilyj
    Re: Lossing my contours in Civil3D 2013
    12-18-2012 01:52 PM in reply to: RafaelMoreno
    Do you have Level of Detail switched on?
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    12-18-2012 02:47 PM in reply to: neilyj
    Hi:
    Thanks for the answer. I do not what is level of detail so I am not sure if I have it turned on or off. However I think that it is not the problem due I lose contourse for one of the surfaces that I have in the screen. The other one that defines my dams are intact
    Rafael
    *Expert Elite*
    BrianHailey
    12-18-2012 08:54 PM in reply to: RafaelMoreno
    Level of Detail can be found HERE.
    *Expert Elite*
    neilyj
    12-19-2012 12:06 AM in reply to: RafaelMoreno
    If you see this,
    then it is switched on; if not, then post the dwg
    neilyj
    12-19-2012 02:06 PM in reply to: RafaelMoreno
    Hi:
    Thanks for the instruction. I am keeping my contours by now. I hope to follow up just in case I have this problem again. The lavel of detail commna is working by now.
    Cheers
    Rafael
