• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Loss of Data Links
    108 Views, 3 Replies
    12-17-2012 07:21 PM
    We have an issue with an existing project.  When opening the cross sections the existing pipes and surface are no longer connected to the project.  The Data Shortcut connection seems to be correct. How do we reconnect the surface and pipe networks to the cross sections?
    Please use plain text.
    AllenJessup
    Re: Loss of Data Links
    12-18-2012 06:55 AM in reply to: rcallison
    You could start by using the Data Shortcut Editor to check you have the current path in the shortcut file.
    You could also try to Validate the shortcuts to see if there are any problems.
    If everything is OK. Synchronize may bring things back.
    Active Contributor
    12-18-2012 02:46 PM in reply to: rcallison
    I tried both with no success.  when I validate the Data shortcuts the following message comes up.
    Shortcuts-C62628DB-2B31-4347-97EB-BC992BF81F3D)
    Validated 78 of 78 shortcuts.
    The data shortcut folder should be as shown below.
    *Pro
    12-19-2012 11:41 AM in reply to: rcallison
    It looks to me like you may want to consider the possibility that the objects got deleted.   There doesn't seem to be any problems with the data shortcuts.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
