• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Accepted Solution
    Looking for a way to capture the drag distance of a label...
    84 Views, 5 Replies
    12-13-2012 08:46 AM
    Hello all,
    Does anyone know a way to capture the drag distance of a Civil 3D label object?
    If that was a property, then we would be able to make our Leaders display or not display based on the distance from the object. If I only drag a label a half-inch I might not want a leader, but if I go further I would like the leader to appear.
    It would be easy enough to do this with expressions if you could make that property available in the expressions dialog.
    Thanks in advance for any ideas,
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Please use plain text.
    *Expert Elite*
    Re: Looking for a way to capture the drag distance of a label...
    12-13-2012 11:19 AM in reply to: tcorey
    Tim, C3D2013's .NET API provides the necessary Label object properties to do this programmatically. Can't think of any other way, other than manual visaul inspection, right now.
    *Expert Elite*
    12-13-2012 01:13 PM in reply to: Jeff_M
    That's what I figured. Thanks, Jeff.
    Tim
    Tim Corey, Owner
    Redding, CA
    *Expert Elite*
    12-13-2012 02:19 PM in reply to: tcorey
    Actually, I found that working with cogopoints is a bit different than most labels. Here's a quick video of the what can be done though:
    http://screencast.com/t/iPz6sngUA
    For this I used the Point.Location and Point.LabelLocation properties to determine whether to use the leader or omit it.
    *Expert Elite*
    12-13-2012 02:26 PM in reply to: Jeff_M
    That's a custom routine, right? You're not accessing Point Labellocation other than through .Net?
    Tim Corey, Owner
    Redding, CA
    *Expert Elite*
    12-13-2012 02:48 PM in reply to: tcorey
    Correct, Tim. Programming only.
