• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Lock Points
    191 Views, 6 Replies
    10-02-2012 09:39 AM
    Is there a way to lock the X,Y location of points so that they don't get moved but still be able to change the point style fo the locked points?
    Please use plain text.
    Valued Mentor
    Valued Mentor
    sjg
    Re: Lock Points
    10-02-2012 10:14 AM in reply to: AEC_Cadd
    If you import points through the survey database, they are automatically locked,. But if you just insert points or creating your own points, select one, right click, select lock points. You should be able to use select similar and lock multiple at once.
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    Re: Lock Points
    10-03-2012 08:57 AM in reply to: sjg
    Thanks Steve, but what I want to do is lock a group of points at their X,Y location but still be able to change their Label Style.
    Valued Mentor
    Valued Mentor
    sjg
    Re: Lock Points
    10-03-2012 09:11 AM in reply to: AEC_Cadd
    Create a point group, include the points you want to include. Right click point group, lock points. Points will be locked in X,Y and you can change the point and label style of the group.
    Steve Goessling
    Land Consultants
    Windows 7, 64 bit
    16 GB RAM
    Nvidia Quadro 600
    Re: Lock Points
    10-03-2012 09:31 AM in reply to: sjg
    Steve
    I did what you said but if you lock the points in a point group, there is no way to change the point style. I know you can lock the point group and still change the point style but you can also move the points. I want some way to lock the point X,Y location so that I don't accidently move a point but still be able to change the point style. Perhaps I am missing something. I tried it in both the Civil 3D 2010 and the Civil 3D 2013. There is a way to lock point locations in LDT and I want to be able to do the same kind of thing in Civil 3D.
    Valued Mentor
    Re: Lock Points
    10-03-2012 09:40 AM in reply to: AEC_Cadd
    I find that the best way to do this is to export the points and import them into a survey database, that way there locked and retained for import later into other drawings as needed.
    Re: Lock Points
    10-03-2012 09:48 AM in reply to: rl_jackson
    Thanks, I appreciate your help.
    Bob
