AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Linking a dwg to annother dwg for updating styles and layers
- Highlight
- Email to a Friend
- Report Inappropriate Content
I am using Civil3D 2013. I was wondering if there was a way to link your dwg to a master dwg file? For example, if i were to copy the dwg into folder A and copy a dwg into folder B. I would then update the master dwg with either a layer color change or linetype or add a layer / label etc, could those changes from the master be (linked) or a child or the parent master dwg? Or does this work with dwts?
Thanks for the feed back.
Re: Linking a dwg to annother dwg for updating styles and layers
- Highlight
- Email to a Friend
Sounds like you may be coming from the MicroStation world where you have dgn libraries to contain symbology definitions instead of everything being stored in your design file.
I've found no equivalent in the Autodesk world (would be great if they could implement it!)
FL. Dept. of Transportation
CADD Applications Developer
HPxw4600 Workstation
Core 2 Duo 2.33ghz, 8gb RAM
nVidia Quadro FX1700
Win7 64bit
- Highlight
- Email to a Friend
The ImportStylesAndSettings command can help port new and edited styles back into your template and from your template to a working file.
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
- Highlight
- Email to a Friend
Hi John
When you say port back to template do you mean open the template and bring in from another file? I don't see an option to push out to file. Also, I tried an experiment and created a blank dwg with the Cadet then use the the ImportStylesandSetting; the check box for settings was selected but none of the ambient setting came with the style?
2012: Am I missing something?
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Highlight
- Email to a Friend
Joe, have a look at the comments from Matt here:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Upg
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
No, you are not missing anything, I think you nailed it on the head. It would be nice to link all the settings , layers etc, to one master dwg.
- Highlight
- Email to a Friend
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
- Highlight
- Email to a Friend
Hey Joe.
I don't really use the command for settings. I use it for moving styles into a file. Either a working file or my template.
Sorry if I got you thinking it will push styles out but we know that doesn't happen. Yes the command could use improvement but if you just want to move a few styles I find it faster than opening a file then draging and dropping.
Relating to another post we have both commented on, I have a hunch that this command is the culprit in the labels changing text styles issue. Simialer to Matt I'll give a 'user beware', better yet a 'user be informed' warning.
C3D 2012, RD 2012
Win 7 64, Core i7,
- Highlight
- Email to a Friend
Yes it would be real nice to have a one stop shop for proting this stuff. Most of my new styles are created in working files as need dictates. How nice would it be to be able to right click on any object or label style and see a comand like, 'Push Style to Template'.
As for the layers, text styles, dimension styles, bloocks/symbols, etc. One of what I am sure is many solutions is to place these objects into a simple AutoCAD template file w/o any civil 3d styles or settings. This template can be inserted into any file as a block to get the AutoCAD stuff it may be missing. Following Autodesk Best Practices' this should be rare since all C3D files should start with the C3D template which should also have these AutoCAD objects/settings.
C3D 2012, RD 2012
Win 7 64, Core i7,
