• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    sadekcivil
    Link Code Hidden in Corridor Section View
    355 Views, 10 Replies
    11-24-2012 10:01 PM
    I have a problem with editing in link code because it didn't appear in corridor section view as you can in attached files.
    And i think the problem appeared because there were some additional subassmbly (not original Subassembly) beside the original Subassembly and i also checked my sample lines and it didn't intersect alignment twice as if you think it intersected alignment.
    Any advice will be appreciate
    Thank you.
    Please do not forget approve as solutions and Points
    to Remember Please Accept as Solution and Kudos Please
    Please use plain text.
    sadekcivil
    Re: Link Code Hidden in Corridor Section View
    11-26-2012 03:04 AM in reply to: sadekcivil
    Any advice Please
    *Expert Elite*
    11-26-2012 11:42 AM in reply to: sadekcivil
    Post your drawing...
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Distinguished Mentor
    11-26-2012 05:46 PM in reply to: sadekcivil
    Try checking your Front Clip and Back Clip distances in the section editor, in View/Edit Options.
     Mine are set to 0.1 and -0.1.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    sadekcivil
    11-27-2012 10:13 PM in reply to: andrewpuller3811
    Thank you Mr.Andrew for your effort.
    As you can see in attached file iset all thing as your setting but nothing happen.
    I think my issue here as you can in attached file there are additional subassemblies(fake) beside my original one and let me tell other station had a link code and everything was ok because there weren't any additional subassemblies.
    May if you haven't any idea i will post my DWG.
    Thank you.
    sadekcivil
    11-28-2012 03:07 AM in reply to: sadekcivil
    I figure out an issue and let me explain what happened.
    Additional subassemblies(fake) appeared at hairpin location only
    As you can see in attached file i have a hairpin in my project
    For your Advice
    Thank you
    11-28-2012 02:20 PM in reply to: sadekcivil
    In the section editor, you can use the "Viewport Configuration" command on the "View Tools" tab to set the view to show the plan and section (and the profile) which might have shown this a a bit earlier.
    Andrew Puller
    Civil 3d 2013 64bit
    sadekcivil
    01-01-2013 02:21 AM in reply to: tcorey
    Dear Mr.Tim,
    Can you give your email because i can't upload more than 1.5Mb here in this forum
    Thank you.
    sadekcivil
    01-01-2013 03:19 AM in reply to: sadekcivil
    Dear Sir,
    You can download my file that describe my issue from the following link:
    Your files are ready to be downloaded by your recipients
    Download expiry date:Friday, January 04, 2013 12:17 PM
    Download limit:10 times
    Password:-
    Link to download page:
    https://www.filemail.com/dl.aspx?id=SZQQQEHTHZQGNAO
    *Expert Elite*
    BrianHailey
    01-02-2013 07:38 AM in reply to: sadekcivil
    The drawing you shared the links show up just fine on my system. You can see it HERE.
