• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Lines show up as foggy grey but don't have that property
    359 Views, 10 Replies
    10-02-2012 05:15 PM
    The above sums it all up. Note the properties are NOT GREY they are what they are supposed to be.
    The file was created in version 2012 by another designer now it is being completed in 2013 by myself.
    I can do a quick fix by creating a wblock of the problem lines and text etc to enable a print out without the GREYING
    problem but once the drawing is closed and opened once again the drawing has GREYED whatever is in model space again.  (note that xrefed lines etc are fine)
    Please help me fix this.
    Regards
    Carla Featherstone
    Ps I have attached the problem file with all the xrefs and jaz unattached/taken off etc
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: Lines show up as foggy grey but don't have that property
    10-02-2012 06:55 PM in reply to: featho
    dumb question but I'll ask it.
    I dont have cad handy but in the plot settings is "display plot styles" checked?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    10-02-2012 07:50 PM in reply to: featho
    I don't know what causes this, or how to correct it, but the 2d Wireframe Visual Style is messed up. Chnage to any other visual style and the linework shows correctly, change it back the the 2d wireframe and it gets hosed. You can work around it by inserting the drawing into a new drawing, then use Design Center to bring in the layouts.
    Jeff_M, also a frequent Swamper
    Active Contributor
    10-03-2012 04:18 PM in reply to: Joe-Bouza
    No it isn't checked
    Edited by
    Discussion_Admin
    Active Contributor
    10-03-2012 05:57 PM in reply to: Jeff_M
    Thanks Jeff I'm pretty sure that inserting into another drawing doesn't work too. That was interesting about the wireframe. Not sure what to do still Thanks for your time Carla
    Edited by
    Discussion_Admin
    *Expert Elite*
    10-03-2012 06:22 PM in reply to: featho
    Carla, I tested the inserting to another drawing, using your drawing, and did work for me. Perhaps your template has the same issue? Could you try with a different dwt?
    Active Contributor
    10-03-2012 06:25 PM in reply to: Jeff_M
    So you inserted a wblock into another drawing? Is that right? I will give that a go now to check it Talk soon
    Edited by
    Discussion_Admin
    *Expert Elite*
    10-03-2012 07:48 PM in reply to: featho
    I just started a new drawing, then used INSERT to insert your entire drawing into the new one.
    New Member
    10-05-2012 05:14 PM in reply to: featho
    I just read this post about an hour ago:
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/text-and-line-work-in-model-space-turns-gray-when-I-r...
    Sound about the same to me.
    *Expert Elite*
    10-05-2012 06:06 PM in reply to: bobwesterman
    Sure enough. It's late Friday afternoon and I can say I learned something today! :smileyhappy:
