AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Lines not printing behind screen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Has anyone seen this before and possibly know a solution?
I have a drawing with a screen and behind it is an xref drawing. When I print it to our KIP plotter the lines and other items behind the screen do not plot.
Here is how it is setup and what I have tried
The Xref itself is on its own layer and all the layers of the xref are set to a color that has thickness of .0138 and a 35% screen.
The hatch resides in the active drawing and is set to a color that is also .0138 thick but at a 20% screen.
The hatch is a DOT hatch at scale 1, but I have also tried it as a solid hatch
Lines merge is on and needs to be on.
I have made sure that the hatch is sent to the back and that there is no overlapping of data from other sources liek a second hatch or the same data in another xref etc.
I also tried setting the xref layers to another color that is .0256 thick with a 35% screen, but the results where the same. If i change the xref layers to a .0138 thick color with 100% screen, they do print over the hatch then.
I have also found that if I use the same plotter but with a post script drive, it does work as setup, though that creates other issues that are not ideal.
Re: Lines not printing behind screen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the plotter settings, do you have it set to Lines Overwrite, or Lines Merge?
*Civil 3DJ*
Todd Rogers
Visit my blog here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You might want to try Lines Overwrite. See if that works...
*Civil 3DJ*
Todd Rogers
Visit my blog here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is not much different between 20% and 35% screen. Try using a 40% or 50% instead, also if the hatch is in his on layer assign a transparency value to it (that may help, but turn on transparency on the plot settings)
