• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    willpyle7693
    Lines by bearing input
    262 Views, 5 Replies
    01-22-2013 01:02 PM
    when trying to input the bearing in degrees minutes and seconds I have to input (for example) 89%%d49'38". how do i change it so i can input ddmmss?
    Please use plain text.
    *Expert Elite*
    Re: Lines by bearing input
    01-22-2013 02:07 PM in reply to: willpyle7693
    This depends on which routine you're using to draw the line. Using just AutoCAD commands, you're doing it the right way. Civil 3D makes it easier.
    After you start the line command, pick the start point and then at the Next Point prompt, type 'bd <enter> -- include the apostrophe. Civil 3D will prompt for quadrant (1-4), then Bearing and then distance. Bearing can be input as 45.4545 to mean 45 deg 45 min 45 sec.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Member
    01-22-2013 02:34 PM in reply to: tcorey
    As an alternate method, go to the Ribbon, select the Home tab and find the Line button on the "Draw" palette.  From the menu, select "Create Line by Bearing".  You will be prompted for your quadrant, bearing and distance (as willpyle7693 instructed above).  One further note, if your bearing has decimal seconds (i.e., 39D 45' 28.72") you may enter the decimal portion like so: 39.452872.
    Distinguished Contributor
    01-22-2013 03:32 PM in reply to: willpyle7693
    I think you are after.
    Drawing Settings  ---> Ambient Settings ---> Direction
    Active Contributor
    willpyle7693
    02-05-2013 11:48 AM in reply to: Chasethewind
    Forgive me, but where do you find that drawing settings box?
    Active Contributor
    willpyle7693
    02-05-2013 11:54 AM in reply to: Chasethewind
    nevermind i found it thanks
