• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Lighting Software
    174 Views, 4 Replies
    01-09-2013 01:23 PM
    Hello all,
    What are people using for street lighting design?  Usally we have farmed it out to lighting contractors, but that is not ideal anymore.  I've looked at Autolux and AGi32; I don't feel super confident about either choice, except that Autolux runs through cad, which I prefer.
    Any thoughts are greatly appreciated.
    Thank you,
    Rand Waltz
    Please use plain text.
    Active Contributor
    Re: Lighting Software
    01-10-2013 09:43 AM in reply to: rand
    The last place I worked could only afford GE Alladin (Free).  If you can find it for download it will get the job done, without fancy graphics.  My concern with it would be if it can properly simulate photometrics for the new LED cobra heads with their different dispersion areas even if you gave it the IES file.
    On the other side I have heard good reports from people I know that use AGI32.
    01-10-2013 12:01 PM in reply to: rand
    I can highly recommend Autolux. I used it extensively at a former place of employment. I found it relatively easy to learn and a pleasure to use. It does come with a good tutorial which helps you learn the menus. Best of all, there is no need to go through the chore of importing / exporting dxf files.
    Active Contributor
    01-11-2013 10:27 AM in reply to: rwhitlock1
    Yeah, that's the one I'm leaning towards.  I called them up to ask some questions (before starting this post) and they said I should call this guy who actually designed the software; all they do is take the credit card.  Also, looking at the install directions, there's a lot of CUI work; did you have to do this? I dread working on the CUI; too many bad experiences.  Anyway, that's why I'm hesitant.
    Many thanks to you and brian.strandberg for your input; I appreciate it.
    Rand Waltz
    01-11-2013 01:58 PM in reply to: rand
    Hey, Rand. My recollection is that we used a simple "menuload" command to load the Autolux menus. It wasn't really elegant but we had some technical issues getting the server to find the licenses, initially. The IT folks eventually set up the menu system with a tutorial supplied with the software. Apparently, it was a step by step thing that was put together with clear instructions.
    Good luck on your eventual choice.
