• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Lidar Tutorial - Problem with Style Selection
    318 Views, 6 Replies
    05-31-2012 12:43 PM
    In the Tutorial: Working with Point Clouds, Exercise 2 choosing the point style "Lidar Point Classification" doesn't change anything.  I should be seeing the points colored according to classification but instead all points just revert to gray.
    Please use plain text.
    Product Support
    Matt_Haokip
    Re: Lidar Tutorial - Problem with Style Selection
    06-05-2012 01:37 PM in reply to: robert.thomson
    Hi Robert,
    It appears that you might have missed one of the steps in the tutorial as I do not see any issue with it, after applying the point could style, the program shows all the elevation ranges based on the color scheme.  Make sure that you select Elevation Ranges for the Point Cloud Style within the Information tab and Apply and from the Elevation Ranges tab, you click Reset from style and Apply and OK to the window.
    Below is the link to the screenshot of my Civil 3D 2013: http://www.screencast.com/t/RVqBKbXfrLm
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Mangkhothang (Matt) Haokip
    Product Support Specialist
    Autodesk, Inc.
    06-07-2012 07:37 AM in reply to: Matt_Haokip
    It's not the Elevation Ranges style I'm having problems with.  It works just fine.  It's the Lidar Point Classification style.
    I'll try and run through the entire exercise sometime soon but we are quite busy here.
    randcdavidson
    10-25-2012 11:37 AM in reply to: robert.thomson
    Robert. Ever get an answer to this? Saw that it was back in June then the Autodesk Tech bailed on the problem. I have had the same issue with the Lidar classification color not working.
    10-26-2012 06:20 AM in reply to: randcdavidson
    No, I didn't. Glad to know it's just not me!
    Active Contributor
    12-11-2012 08:24 AM in reply to: robert.thomson
    Yeah Autodesk definitely dropped the ball on this one.  It'd be something if it hadn't worked in 2012, but it did.  Now whenever I have to do LiDAR work, I have to go back and use 2012.  Autodesk, hopefully you get your stuff straight for 2014
    New Member
    01-01-2013 03:30 PM in reply to: jeremy.2012
    I don't see the LIDAR Point Classification, Point Cloud Style working either, just grey no color variation. Yes the Elevation Ranges, Point Cloud Style display correctly but not LIDAR. So point clouds are not fully supported in Civil 3D 2013? Frustrating tutorial.
