• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    yazzie91
    Accepted Solution
    Leader vertex does not connect to line when changing scales
    174 Views, 7 Replies
    11-15-2012 04:12 PM
    I’ve had this problem with my proposed elevations for quite some time so I finally want to fix it while I’m a little slow. The problem I have is when I change scales, my elevation’s (in dragged state) leader vertex does not connect to my line. I’ve attached my lable styles so hopefully someone can give me a few pointers.
    Please use plain text.
    *Expert Elite*
    BrianHailey
    Re: Leader vertex does not connect to line when changing scales
    11-15-2012 06:33 PM in reply to: yazzie91
    Post up a drawing with the style so we can take a look at it.
    Or, if you would rather, you can send it to me directly. I have a gmail account named c3dplus you can send it to if you want.
    yazzie91
    11-16-2012 07:52 AM in reply to: yazzie91
    Here it is
    *Expert Elite*
    Joe-Bouza
    11-16-2012 08:00 AM in reply to: yazzie91
    Nice looking plan.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    yazzie91
    11-16-2012 08:07 AM in reply to: Joe-Bouza
    Joe-Bouza wrote:
    Nice looking plan.
    Thanks........I hope that's not sarcasm.
    I made the jump from 2000 LDD to Civil 3D about 18 months ago and still trying to perfect my styles.
    *Expert Elite*
    Joe-Bouza
    11-16-2012 08:30 AM in reply to: yazzie91
    I must have a rep.
    Nope I was genuine :smileywink:
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    11-16-2012 08:59 AM in reply to: yazzie91
    You need to use some different techniques. Right now it appears you are moving the leader vertex when the label is dragged to the left. When you change scales, the leader's vertex remains where you moved it to.
     Here a couple ways to address this:
    Set the label style's dragged state to Stacked Text, where upon you lose the line in the label but at least the text will flip to the correct side.
    Create a child style, but have it initially go to the left. Then you will use both styles for the labeling, one for the right offsets and one for the left offsets. Attached are 2 images for 10 & 20 scale using this method:
    yazzie91
    11-16-2012 09:33 AM in reply to: Jeff_M
    Thanks! I was hoping I could do it all in one style, but this will work fine.
