• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Layer problem
    177 Views, 4 Replies
    11-13-2012 11:55 AM
    In model space if i go to layers manager and turn off a layer why does it still show up in model space.  Civil 3d 2013
    Please use plain text.
    Distinguished Contributor er
    Re: Layer problem
    11-13-2012 12:21 PM in reply to: forrest16
    If you do a  REGEN, does the layer become visable? If so, check your REGENAUTO setting, it may be turned off.
    New Member
    Re: Layer problem
    11-13-2012 12:28 PM in reply to: forrest16
    my regen auto is on.  but my problem is when i turn a layer off it still shows in model space.  if i freeze the layer then it turns off but if i simply turn the layer off it is still visible.
    *Expert Elite*
    Re: Layer problem
    11-13-2012 01:40 PM in reply to: forrest16
    There is a setting for layers that are off to either not display, or lock and fade.  Is it doing the lock and fade for you?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    Joe-Bouza
    Re: Layer problem
    11-13-2012 03:09 PM in reply to: forrest16
    If the components of the object are on different layers turning off the insert layer would not turn off the component layer.
    Example:
    default layer for point insert = V-node
    marker style layer  = c-topo-spot
    label style layer = V-node-text
    turn "off" v-node and the point and label style remain. freeze v-node they all go.
    Think of c3d ojects as nested blocks made of components on thier own layers and it has a singular insert point
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
