AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Layer problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In model space if i go to layers manager and turn off a layer why does it still show up in model space. Civil 3d 2013
Re: Layer problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you do a REGEN, does the layer become visable? If so, check your REGENAUTO setting, it may be turned off.
Re: Layer problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
my regen auto is on. but my problem is when i turn a layer off it still shows in model space. if i freeze the layer then it turns off but if i simply turn the layer off it is still visible.
Re: Layer problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is a setting for layers that are off to either not display, or lock and fade. Is it doing the lock and fade for you?
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
Re: Layer problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If the components of the object are on different layers turning off the insert layer would not turn off the component layer.
Example:
default layer for point insert = V-node
marker style layer = c-topo-spot
label style layer = V-node-text
turn "off" v-node and the point and label style remain. freeze v-node they all go.
Think of c3d ojects as nested blocks made of components on thier own layers and it has a singular insert point
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
