• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Layer not what it appears to be
    104 Views, 2 Replies
    04-26-2012 09:10 AM
    At this time, this is my biggest complaint with Civil 3D: My drawing has many layers and overlapping objects and it's necessary to use layer manager constantly. Therefore, I will only have layers on that I need at any given time. So I'm working on a corridor, and I create temporary alignment station/offset labels. I have a style whose layer is, let's say XYZ. In the drawing I'm on layer 0. I place the label, and it does not display. After turning on all layers, and searching throught the congestion and finally locating my label. I click on it, and properties says it's on layer 0. My style says it's on layer XYZ, but by process of elimination, I find that it's on the layer of the alignment. Does anyone have a work-around that would make this simpler? I understand about default layers under "edit drawing settings", but do I have to change this everytime I create an object or text? I would love to be able to override the default layer.
    Randy A. Owens
    Southland Engineering, Inc.
    Win 7 64BIT
    C3D 2013
    Please use plain text.
    Valued Mentor
    IanMcClain
    Re: Layer not what it appears to be
    04-26-2012 01:50 PM in reply to: randyowens3203
    Change your styles to be on layer 0, then your objects will inhert the properties of the current layer, much like blocks. You can control what defualt layers the objects get created on by going to Drawing Settings and looking in the Object Layer tab.
    -Ian McClain
    (running C3D 2012 sp3, Win7 64bit)
    Valued Contributor
    04-27-2012 05:09 AM in reply to: IanMcClain
    That sounds like a good idea. I'll give it a try. Thanks.
    Randy A. Owens
    Win 7 64BIT
    C3D 2013
