• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Layer filters stop working
    107 Views, 3 Replies
    01-22-2013 06:57 AM
    I am using 2013 C3D with SP1. After I publish sheets using the sheet set manager my layer filters stop working (will not filter layers, it will just display the last layer filter used prior to running the sheet set manager). Any help on this is appreciated.
    Please use plain text.
    *Expert Elite*
    Re: Layer filters stop working
    01-22-2013 09:01 AM in reply to: jak79
    Do Layer Filters work if you set LAYERDLGMODE to 0?
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    01-22-2013 12:58 PM in reply to: tcorey
    That appears to work if I change the setting on "Layerdlgmode" to 0. Problem now is that's not the way I want to run my layer properties manager window. I prefer to have it docked and using auto-hide.
    Thanks for the reply.
    *Expert Elite*
    rkmcswain
    01-22-2013 01:15 PM in reply to: jak79
