• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    dave.babcock
    Layer Manager not showing layers...
    2481 Views, 8 Replies
    01-26-2012 11:02 AM
    When I open layer manager, it doesnt show my layers, it is just all blank, not even a "0" layer. I can click in the area and it shows the layer but that is it. I searched for a fix but was unable to find a fix. I have updated my graphics card driver but that didnt fix it. I have attached a screen shot to show what it looks like. I am running C3D 2009. Thanks for any help.
    Please use plain text.
    Valued Contributor
    Re: Layer Manager not showing layers...
    01-26-2012 12:45 PM in reply to: dave.babcock
    I saw something similar to this with a co-worker's system back in AutoCAD 2009.  Try playing with your display settings.  Also, does anything appear when you type in CLASSICLAYER at the command line?
    Jason
    01-26-2012 01:02 PM in reply to: dave.babcock
    First check if you have checked the "invert Layer Filter".
    And a special question: do you use an Intel graphic card?
    - alfred -
    Alfred NESWADBA
    Active Member
    dave.babcock
    01-26-2012 01:35 PM in reply to: PorterCAD
    I typed CLASSICLAYER and it opened an a layer manager that was good....Thanks. I looked in my docked layer manager and it wasnt fixed there but I can type the command to get it so I can edit layers. Thanks Jason.
    Valued Contributor
    01-26-2012 01:39 PM in reply to: dave.babcock
    Glad that helped out, but it's just a band-aid.  It doesn't resolve the new layer dialog box issue.  I suggest tweaking your display settings or exploring your graphic card as Alfred suggested.
    Good day,
    Jason
    Active Member
    dave.babcock
    01-26-2012 01:43 PM in reply to: alfred.neswadba
    Alfred,
    I do not have the invert layer checked. The graphics card is an ATI FirePro V5800.
    01-26-2012 02:16 PM in reply to: dave.babcock
    Have you checked for the last ServicePacks for Civil3D? (>>>look here<<<)
    Do you have your layer-manager opened on the first or on the secondary monitor?
    And what operating system do you have?
    - alfred -
    Alfred NESWADBA
    Active Contributor
    JessicaPalmer
    01-26-2012 03:05 PM in reply to: dave.babcock
    Dave,
    I have seen this happen with a corrupted desktop shortcut.  Try starting Civil 3d from All Programs ->Autodesj->Civil 3D.  If your layers look fine with this method, you just need to recreate the desktop shortcut.
    Jessica Palmer
    New Member
    jepeit
    02-21-2012 06:16 AM in reply to: JessicaPalmer
    Not sure if this helps the troubleshooting process but I'm seeing the same thing in Autocad Electrical 2010.  It only happens from time to time and restarting autocad fixes it while opening and closing the layer manager doesn't.  Would this rule out graphics card issues?
