• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Laptop Workstation Recommendations for C3d 2013
    835 Views, 7 Replies
    01-11-2013 09:45 AM
    I am on the hunt for a laptop workstation that will handle C3d 2013.  I realize there is a spec sheet listing requirements for the software, but thought someone might have some good advice/pros and cons on machines they are using.
    Please use plain text.
    *Expert Elite*
    AllenJessup
    Re: Laptop Workstation Recommendations for C3d 2013
    01-11-2013 10:49 AM in reply to: rsBria
    Really depends on how much you want to spend. The usually advice is get the best you can afford. The usual top 2 for Civil are Memory and Processor Speed. There are some advantages with SSDs if you can afford one.
    I've had a Sager in the past. My last laptop I got from the Dell Outlet site. A reconditioned M6500 for about 2 grand. It's been working great for the past couple of years.
    Allen
    *Expert Elite*
    sboon
    01-11-2013 09:59 PM in reply to: AllenJessup
    My laptop specs are part of my signature.  I've been running Civil 3d on it since 2010.  It's a heavy beast to carry around but I like it as a CAD system.
    Active Contributor
    01-12-2013 10:06 AM in reply to: sboon
    I use Civil 3D 2012 on a ASUS G73SW gaming laptop. Most of my grading work is in mountanous regions with massive surface data. Even though my graphics card is not supported by Autodesk, I am currently not having any problems. I had to adjust the video card setting slightly in the beginning.
    ASUS G73SW
    8 GB RAM
    i7 processor 2630QM
    64 bit window 7 (love it!)
    NVIDIA GeForce GTX 460M with CUDA - 1GB video memory
    700GB hard drive. Not sure of the manufacturer (this seems to be holding this laptop back).
    I am looking into SSD, but I heard Civil 3D's temp files never truly delete on SSD drives and therefore will eventually fill the hard drive until it is disabled. Now... the source of this info is a great IT guy, but doesn't know much about Civil 3D, so take it as you will. I had a workstation that the SSD hard drive filled up to critical, in about 6 months. IT told me it was the way Civil 3D handles temporary and operating files.
    Windows 7 64
    Intel Core i7 2.0 GHz 2.0 GHz
    8 GB RAM
    Nvidia GeForce GTX460M
    Civil 3D 2012 SP2.1
    *Expert Elite*
    01-12-2013 10:42 AM in reply to: d1of2
    Change where Windows' TEMP folder is located. I did this by moving all of my USER files from the SSD to my data drive using a Symbolic link so everything thinks it is still on the C: but it is actually on my E: I've been using this laptop, with a 128gb SSD, without issue for 2+ years.
    01-14-2013 10:55 AM in reply to: rsBria
    Thanks for the input.
    Active Contributor
    01-24-2013 12:27 PM in reply to: Jeff_M
    thanks Jeff!
    I was wondering how long it was going to take me to run into someone from the swamp! Gooday
    Windows 7 64
    8 GB RAM
    Civil 3D 2012 SP2.1
    02-01-2013 05:42 AM in reply to: rsBria
    Thanks for all the input.  I went with a Toshiba X875Q7380, but it came with windows 8.  I am going to have to strip 8 off and install 7.
