• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    MattHough2641
    Labeling Pipe crossings in Plan view
    275 Views, 4 Replies
    07-11-2012 01:24 PM
    Hello everyone,
    I am trying to figure out how to label pipe crossings in plan view.  For example it is my companies standard practice to label all crossings of Storm and Water.  The text usually reads as follows:      IE 12" SD=XXX.XX
        TOP 8" W=XXX.XX
    Is this possible in civil 3d 2012?  I have 2 seperate pipe networks (of course =) ).  Is there a specific label component I'm just not seeing?
    Please help...I need as much as I can get?
    Please use plain text.
    Product Support
    Re: Labeling Pipe crossings in Plan view
    07-16-2012 07:12 AM in reply to: MattHough2641
    Hi Matt-
    After looking into this I had initially thought using a Reference Text component may be able to be used, but it doesn't look like that is the case. Unfortunately I am not sure if this is possible, especially with two separate networks. Any one else out there require such a label, and if so, what methods are you using??
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    MattHough2641
    07-17-2012 10:42 AM in reply to: SethHall
    Thank you for the heads-up, Seth.
    *Expert Elite*
    07-19-2012 06:45 AM in reply to: SethHall
    SethHall wrote:
    Hi Matt-
    Yes, I require this type of label. What I do now? MLeader and calculator....
    Jeff_M, also a frequent Swamper
    New Member
    JMcCoskey
    07-19-2012 11:19 AM in reply to: Jeff_M
    This is the best work around I have found.  Certainly this is something one would expect to see in civil design / sheet generation program, but............
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Label-pipe-invert-in-plan-view/m-p/2536859/highlight/...
