• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Label widths of roadway
    150 Views, 9 Replies
    01-21-2013 02:44 AM
    I'm working on a windfarm access road with tight bends that need to be 2.5m wider than the straights. I have created offset alignents and the corridor with no problem but how can I label the widths to show the variation in width at the various locations. The road is at the full width (7.5m) between tangent points and then tapers to the standard width of 5m
    I have shown simple aligned dimensions on the screenshot but I'm sure there will be a way to do this automatically - won't there?
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    *Expert Elite*
    johnm
    Re: Label widths of roadway
    01-21-2013 06:35 AM in reply to: neilyj
    I have not done anything like this but I am wondering if you can have alignments on both sides and report in a label the offset form on alignment to the other or an expression to double the offset from a centerline...
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    neilyj
    01-21-2013 06:46 AM in reply to: johnm
    I'll look at expressions but although the widening isn't symetrical about the centreline (it's 2.5m each side and an additional 2.5m at bends)
    I'd normally just use a dimension but this is a work in progress and I'm still grip editing it around to get a decent layout
    neilyj
    *Expert Elite*
    Joe-Bouza
    01-21-2013 07:10 AM in reply to: neilyj
    Is you dimension style associative? I don't know if it woks with c3d object it does with plain acad lines and curves. I wonder if that could be put in a corridor style
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    johnm
    01-21-2013 07:12 AM in reply to: neilyj
    I had a couple of minutes to look at this. There has to be a way to get the line to goo across the street and get two arrow blocks lined up similar to a profile VC label.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    *Expert Elite*
    neilyj
    01-21-2013 07:20 AM in reply to: Joe-Bouza
    Don't think annotative works with Civil objects unfortunately
    neilyj
    *Expert Elite*
    Joe-Bouza
    01-21-2013 07:24 AM in reply to: neilyj
    You meant associative, right?
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    neilyj
    01-21-2013 07:29 AM in reply to: Joe-Bouza
    Ooops... senior moment.:smileyembarrassed:..yes associative
    neilyj
    *Expert Elite*
    Joe-Bouza
    01-21-2013 07:31 AM in reply to: neilyj
    Funny my minds eye pictures you as a youngin.
    I just check: no association to c3d objects
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    neilyj
    01-21-2013 07:33 AM in reply to: Joe-Bouza
    :smileyvery-happy:
    neilyj
