AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Label curve radius via label set
- Highlight
- Email to a Friend
I have manually added labels to an alignment curve to show radius/distance - is this possible to do automatically via a Label Set?? If so, how do I do it
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Re: Label curve radius via label set
- Highlight
- Email to a Friend
Set your default label style to Distance over Radius or your equivalent. Go to Annotate > Labels & Tables > Add Labels > Alignment > Single Segment. Select the arc and that should add the Label you want.
Allen
- Highlight
- Email to a Friend
That's how I did it - I wanted to know if this was possible to do in the same way that chainages and tangent points are added as part of the Label Set??
- Highlight
- Email to a Friend
You would do that with Multiple Segments instead of Single Segment. But I can't figure out where to change the Label Style. My Default is set for Distance over Radius. But I keep getting Delta, Radius, Tangent and Length.
Allen
- Highlight
- Email to a Friend
OK. If I use Multiple Segments from Line Curve instead of Alignment. It uses the Distance over Radius Style. I still don't see where to change it for the Alignment set.
Allen
- Highlight
- Email to a Friend
Got it. You need to change the Feature drop down to Alignment instead of Line & Curve.
- Highlight
- Email to a Friend
Excellent - thanks
- Highlight
- Email to a Friend
I've modified my style to only show the radies but the straights are still getting labelled (easy enough to Select Similar to delete them though)
- Highlight
- Email to a Friend
You could just make a _NoDisplay Line Label Style and remove all the components. Then all you'd get is the curves. Or is that what you've done?
Allen
