• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Accepted Solution
    Label curve radius via label set
    708 Views, 8 Replies
    08-19-2011 02:15 AM
    I have manually added labels to an alignment curve to show radius/distance - is this possible to do automatically via a Label Set?? If so, how do I do it
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    *Expert Elite*
    AllenJessup
    Re: Label curve radius via label set
    08-19-2011 06:39 AM in reply to: neilyj
    Set your default label style to Distance over Radius or your equivalent. Go to Annotate > Labels & Tables > Add Labels > Alignment > Single Segment. Select the arc and that should add the Label you want.
    Allen
    *Expert Elite*
    neilyj
    08-19-2011 06:45 AM in reply to: AllenJessup
    That's how I did it - I wanted to know if this was possible to do in the same way that chainages and tangent points are added as part of the Label Set??
    neilyj
    *Expert Elite*
    AllenJessup
    08-19-2011 06:59 AM in reply to: neilyj
    You would do that with Multiple Segments instead of Single Segment. But I can't figure out where to change the Label Style. My Default is set for Distance over Radius. But I keep getting Delta, Radius, Tangent and Length.
    Allen
    *Expert Elite*
    AllenJessup
    08-19-2011 07:05 AM in reply to: AllenJessup
    OK. If I use Multiple Segments from Line Curve instead of Alignment. It uses the Distance over Radius Style. I still don't see where to change it for the Alignment set.
    Allen
    *Expert Elite*
    AllenJessup
    08-19-2011 07:12 AM in reply to: AllenJessup
    Got it. You need to change the Feature drop down to Alignment instead of Line & Curve.
    *Expert Elite*
    neilyj
    08-19-2011 07:15 AM in reply to: AllenJessup
    Excellent - thanks
    neilyj
    *Expert Elite*
    neilyj
    08-19-2011 07:43 AM in reply to: neilyj
    I've modified my style to only show the radies but the straights are still getting labelled (easy enough to Select Similar to delete them though)
    neilyj
    *Expert Elite*
    AllenJessup
    08-19-2011 07:55 AM in reply to: neilyj
    You could just make a  _NoDisplay Line Label Style and remove all the components. Then all you'd get is the curves. Or is that what you've done?
    Allen
