• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Accepted Solution
    Label assembly with field automatically
    676 Views, 7 Replies
    02-21-2011 07:48 AM
    Found a link to some code (http://c3dxtreme.blogspot.com/2010/12/automatically-label-those-road.html) to automatically place an Mtext field to label assemblies. It was written for C3D 2009/2010 but I can't get it to work for 2011 - any VBA gurus care to take a look to see if it will run (or not) on 2011
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    *Expert Elite*
    Re: Label assembly with field automatically
    02-21-2011 09:21 AM in reply to: neilyj
    Well, I was able to modify the file so it works in both 2009 & 2010. The same file should work in 2011, but I can't test it because I do not want to install the VBA enabler. I've made a few other minor changes as well, but since Justin is the one who posted this routine I feel I should ask him if he'd like to post the revised file or if he wouldn't mind me doing so here. I've sent him an email asking just this....
    Valued Mentor
    02-21-2011 11:57 AM in reply to: neilyj
    Wow, quick work gettingthat link killed!
    *Expert Elite*
    02-21-2011 12:37 PM in reply to: KirkNoonan
    The link is exactly how it's posted on the blog. I think there's a problem there, not with someone "getting it killed". :smileyhappy: Here's a link to the page it's on: C3DExtreme
    Justin has granted permission for me to post the updates here.
    Attached is a zip file with both a VBA and Lisp version of the code. Either should work in any version of C3D. There is a Readme with a little more info.
    *Expert Elite*
    neilyj
    02-22-2011 12:26 AM in reply to: neilyj
    Many thanks Jeff_M (and Justin) for the quick turnaround to this request - I've just tried the lisp version and it works perfectly
    PS in the original link I posted, an extra bracket had crept in at the end so the link didn't work
    neilyj
    *Expert Elite*
    johnm
    02-22-2011 05:03 AM in reply to: neilyj
    Thanks for the additional work of the lisp version. I've been coping mtext objects from assembly to assembly and editing the field. I'll give it a shot in a bit.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Distinguished Contributor
    sadekcivil
    12-30-2012 03:18 AM in reply to: Jeff_M
    I tried to try VBA with Civil 3D 2012 and it didn't work
    Thank you in advance.
    Please do not forget approve as solutions and Points
    to Remember Please Accept as Solution and Kudos Please
    *Expert Elite*
    12-30-2012 07:44 AM in reply to: sadekcivil
    A little more information would be helpful. "It didn't work" is not very descriptive. Were there any error messages or warnings? How did you load and run it? DId you try the lisp version?
    I cannot test it in 2012 because I did not, nor plan to, install the VBA Enabler.
