AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Label assembly with field automatica lly
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Found a link to some code (http://c3dxtreme.blogspot.com/2010/12/automaticall
(No connection with Autodesk other than using the products in the world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Re: Label assembly with field automatica lly
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well, I was able to modify the file so it works in both 2009 & 2010. The same file should work in 2011, but I can't test it because I do not want to install the VBA enabler. I've made a few other minor changes as well, but since Justin is the one who posted this routine I feel I should ask him if he'd like to post the revised file or if he wouldn't mind me doing so here. I've sent him an email asking just this....
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Wow, quick work gettingthat link killed!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The link is exactly how it's posted on the blog. I think there's a problem there, not with someone "getting it killed".
Here's a link to the page it's on: C3DExtreme
Justin has granted permission for me to post the updates here.
Attached is a zip file with both a VBA and Lisp version of the code. Either should work in any version of C3D. There is a Readme with a little more info.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Many thanks Jeff_M (and Justin) for the quick turnaround to this request - I've just tried the lisp version and it works perfectly
PS in the original link I posted, an extra bracket had crept in at the end so the link didn't work
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the additional work of the lisp version. I've been coping mtext objects from assembly to assembly and editing the field. I'll give it a shot in a bit.
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried to try VBA with Civil 3D 2012 and it didn't work
Thank you in advance.
to Remember Please Accept as Solution and Kudos Please
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A little more information would be helpful. "It didn't work" is not very descriptive. Were there any error messages or warnings? How did you load and run it? DId you try the lisp version?
I cannot test it in 2012 because I did not, nor plan to, install the VBA Enabler.
