• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Label Cross Sections
    260 Views, 7 Replies
    01-03-2013 06:25 AM
    When editing the Cross Section Styles the Horizontal Axis changes do not take affect. Vertical will work as entered.
    See attached image.
    I am changing under the Horizontal Axes tab, on the Section View Styles Menu.
    Am I in the right place.
    Thanks!
    Dave...
    Please use plain text.
    *Expert Elite*
    sboon
    Re: Label Cross Sections
    01-03-2013 08:27 AM in reply to: DAVE8171
    It sounds like you're in the right place, but are you changing settings for the Major labels or the Minor ones?
    BTW - Welcome to the board.
    Active Member
    01-03-2013 08:30 AM in reply to: DAVE8171
    Either. No change is displayed...
    Active Member
    01-03-2013 08:39 AM in reply to: DAVE8171
    Attached is the procedure and the result...
    Thanks!
    Dave...
    *Pro
    01-03-2013 10:23 AM in reply to: DAVE8171
    sometimes when I think I know which style my section view is using I try to edit that style and nothing changes like what your seeing.   When actually the style being used by the section view is another style all together.   Could this be the case?
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Valued Mentor
    Valued Mentor
    sjg
    01-03-2013 03:45 PM in reply to: DAVE8171
    They wouldn't happen to be a data band?
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    Active Member
    01-04-2013 05:39 AM in reply to: DAVE8171
    No...
    Distinguished Mentor
    01-06-2013 05:49 PM in reply to: DAVE8171
    Can you post the drawing?
    It is much easier to sort issues like this with the drawing.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
