• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    asloat
    L100 Text printing thin
    147 Views, 4 Replies
    11-16-2012 10:52 AM
    I have a user with Civil3D and he has an odd problem. He has several text objects on several layers that all are assigned the "L100" text style. We use a CTB still and when he prints leaders and other objects on the same layer and same color are normal, but the text itself (mtext) is much thinner.
    I checked the mtext to make sure it was set to "by layer" and everythign seems fine. I then changed the text to "L" style and they immediatly got darker on the screen and now print just fine. When I look at "style" L100 and "L" appear to be indentical.
    Any idea what the issue is here?
    Please use plain text.
    Joe-Bouza
    Re: L100 Text printing thin
    11-16-2012 12:18 PM in reply to: asloat
    Does the style have a font overide?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    11-16-2012 01:54 PM in reply to: asloat
    Post a drawing...
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    asloat
    11-19-2012 05:08 AM in reply to: asloat
    Here is the drawing, I removed everything but one of the mtext entities and a leader. They are ont he same layer and set to color by layer, but if you change the text to L100 you will see it thins.
    Thanks for takign a look!
    Joe-Bouza
    11-19-2012 07:35 AM in reply to: asloat
    L uses simplex.shx and L100 is calling a trutype simplex
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
