AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Joining up borehole strata
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I got a few boreholes in a test drawing and i want to join the various strata horizons (with 3d polys or something) to create surfaces.
Each borehole has several points organised in groups (input via the Borehole Importer Tool) I have gone into a SW isometric view but cannot snap to any of the points that are "below ground". I have got Node OSNAP on but can only select the topmost point every time
Whilst I could create surfaces based on the point groups this will give rise to geologically suspect surfaces so there is a bit of manual interpretation work needed
Can anyone assist with this??
(No connection with Autodesk other than using the products in the world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Re: Joining up borehole strata
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've had similar problems in 2012. I've fooled around with a few fixes. But I usually end up closing the drawing and re-opening it. I haven't been using borehole data. Just regular points at elevation. Sometimes I just can't get the OSnap to work.
Allen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should look at User Defined Point Classifications. This lets you create your own database fields within your drawing point database.
For example, maybe in your borehole data you have a depth to Clay. You could make a user-defined property class for Clay.
Do you have the borehole data in a spreadsheet/CSV/ASCII file? Maybe the file has P#, North, East, Elev, Desc, ClayDepth. Make a point file format that matches, and then when you import, you'll get Clay information.
Now, make a point expression that subtracts the ClayDepth from the PointElevtion. This becomes ClayElevation. Make a Point Group and Override the PointElevation with ClayElevation. Make a surface using that point group.
I can help more if you would like to phone me: 530.221.2994. I will be available Friday after 2pm pst.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Tim - the file was in an AGS format that the Borehole Import Tool can read and has put all the data in Point Groups.
However I just want depths from ground (as the elevation field) as a positive number but the Importer reads it as a negative number so your idea of using expressions may be able to do the maths for me without exporting to Excel and reimporting
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I was hoping I could directly manipulate the points but this doesn't appear to be the case...back to Excel...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Neil, Not sure if this helps but rather than using Points I attach a single point file with differing imports for each layer.
Obviously I initially import the points drape to the EG and export to CSV. Next in excel add in the rest of the data for each layer adjusting to get a real value from EG.
The point file may now have headers such as: E,N,EGL,S1,D1,S2,D2,S3,D3 etc. Where S# is each strata layer and D# is each layers description.
In civil3d you can create import definitions where you add gaps in to only target the column you want each time.
So for S2 & D2 the import columns would look like:
Easting, Northing, Empty, Empty,Empty,Elevation,RawDesc.
Attaching the point file to the surface gives good results especialy after smoothing and switching triangles.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Guys
This may be of interest to you new borehole utility
it will import both CSV and AGS idata nto Civil 3D, and should have the functionality you want, can't say too much at the moment.
Regards
Gary
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
this type of functionality is a major part of my workflow and i wonder what additional/missing functionality is in the civil 3d version of this tool compared with other packages available?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you would post your original data file, I would be willing to use the Borehole Importer to take a look and see if I can come up with a solution. Please disregard my previous post as I missed the part about you using the Borehole Importer.
Best regards,
Tim
Redding, CA
