AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Iterating height levels for a polyline
- Highlight
- Email to a Friend
- Report Inappropriate Content
I have a problem iterating heights when making a polyline between two different points that have Z-values. I've used Autocad Civil 3D for working with geodedic data with height measurements before and I remember using geodetically measured height values, transforming them into a surface and then when I create a 3Dpolyline within this area the polyline automatically gets z-values that change along the line. In other words, I could use this 3Dpolyline to obtain a profile that gives me z-values even where there is no exact point with a value has been physically measured. It was a while ago I worked with Autocad and now when I started again I have a similar problem but can't manage to create a surface and get iterated values.
My exact problem this time is:
I have a sewage pipe that runs for several kilometers that is drawn as a 3Dpolyline, with correct x- and y-values. It doesn't have any z-values yet and these are what I want to obtain. I want the polyline to have continous z-values that changes along the polyline (not only in vertexes) so that a smooth profile can be drawn if wanted. I have data of measured actual z-values for approximately every 500 meters or so along the sewage pipe and these are currently drawn as 3Dpolylines of around 20 meters going perpendicular to the pipe (as in the picture). In other words there are bars with z-values crossing the pipe all along the stretch. Now, what I want to do is to somehow make the polyline that represent the pipe to get the hights from these perpendicular bars with the measured z-values. If I try to draw a new 3Dpolyline between two of the measured bars where the actual pipe is supposed to be, the end vertexes of the 3Dpolyline gets the z-values of the bars. However, the value inbetween the bars gets the Z-value 0. So, if I start a 3Dpoly on bar 1 then continue the pipe with another vertex, and then finish off at the second bar I will have 2 vertexes with the correct z-value but the middle vertex will be incorrect (0). How do I get the pipe to get the correct zvalues automatically iterated from the values on the crossing bars? Is this even possible to do? Should I create a surface from the bars first, and in that case how do I do that? If possible I don't only want the vertexes between bars to have iterated z-values, I also want the entire line to have a correct value.
I've attatched a crappy image made in paint (since I don't have Autocad on my home PC, only at the office). And just to make things even clearer I'll give an example. Let's say the pipe distance from 1 to 2 is 10 meters, the distance between 1 to 3 is 30 meters and the z-values of bar A and bar B is 10 and 25 respecitvely. So, when I draw a 3Dpolyline from 1 to 4, I want the vertex 2 to automatically get z-value 15 (since it's 1/3 on the way to B). In the same way, I would like for example the point on the pipe that is right in between 2 and 3 to have the z-value 20. I won't mind redoing the bars to for example singualar points instead, if that makes it all easier.
I'm really appreciating any help I can get with this! I get the feeling that it's easier than I belive it is to solve, and I feel that it should be possible. I just can't figure out how... =(
Sorry for the long description, I just wanted to make everything crystal clear =)
Thanks!
Re: Iterating height levels for a polyline
- Highlight
- Email to a Friend
(No connection with Autodesk other than using the products in the world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Highlight
- Email to a Friend
Hi, thank you for your reply.
Yes, the bars have the right z-values, and creating a surface was my original thought too. But actually I haven't managed to create a surface sicne Autocad didn't want to recognize the bars as barriers. If creating a surface is the best way, some more info on exactly how to do it and what alternatives to use would be very welcome =)
- Highlight
- Email to a Friend
Create a new featureline and grab the levels from the surface.
you may need to refer to help to achieve some of the above but at least you know what to look for, can't post screenshots as not at PC or laptop...
- Highlight
- Email to a Friend
Thank you for your reply! I quickly tried the same thing last week at work, but somehow when I tried to choose breaklines and pick the bars, "no selection" or something like that was written in the dialouge field. It's like cad didn't want to acknowledge that they are there or are good candidates for breaklines. Do the bars have to have any certain properties? It should work with 3D polylines, right? Maybe I will have to try this all over again at work tomorrow, I wonder what I missed...
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
I can post a part of the drawing tomorrow when I get to work. I will try the to create the surface again as described aswell and see what happens. And if it doesn't work, I'll post a picture here. Thank you for your help =)
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
You can use the surface to get the elevations of the pipes at the locations of your lines but that won't necessarily give you the correct elevation at the pipes themselves.
Watch THIS to see what I'm referring to.
- Highlight
- Email to a Friend
Oh my thank you so much for taking the time making that awesome video! And the solution using points instead of lines for the z-levels will give the correct result now that I think about it - thank you so much for explaining that and how to create the surface to me! Just so you know you've been of great help in figuring out details for modeling the sewer system in Stockholm, Sweden =)
Thanks! <3
