AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Issue while copying centerline alignment with offset alignment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a surface, a centerline alignment, and an offset alignment for the centerline alignment. Also a surface profile for the centerline alignment.
1. When i copy the centerline alignment in another drawing, it gets copied with the surface as well as the surface profile.
2. When i export the alignments using landxml, and import that landxml into another drawing, the offset alignment takes the property of a centerline alignment and that way its link with the original centerline alignment is lost.
Kindly reply for the issue. thanks
Re: Issue while copying centerline alignment with offset alignment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1. Can you explain exactly how you are copying the alignment?
2. I don't believe there is a 'solution' to this. When you export to Land xml the alignment is just an alignment, no specific type. So when you import it back C3D will give it the default type "Centerline". Can you use a data shortcut instead of Landxml?
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It usually causes problems to use the clipboard to copy C3D objects from one drawing to another.
I also think that the LandXML method will drop the offset property of the alignment. Try using either a data reference or simply X-Referencing the alignment into the destination drawing to get the results you expect.
