• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Is CreateROW working in SP1?
    56 Views, 2 Replies
    04-13-2004 10:38 AM
    I have SP1 loaded and I refreshed my menus to see the Create ROW command under Parcels. However, the command asks for the selection of Parcels and everything I select says it was filtered out, whether parcel objects, alignment objects, polylines, etc. What am I doing wrong, or is this feature working yet?
    Please use plain text.
    *Tyler Townes
    Re: Is CreateROW working in SP1?
    04-14-2004 02:54 PM in reply to: DannyCounts
    Danny, I was able to select parcels by selecting the parcel description text (lot#, acreage...). I am, however, not quite sure exactly how it works. It does create ROW, but when the alignment is moved the parcels do not update. Tyler Townes "DannyCounts" wrote in message news:20467009.1081877968218.JavaMail.jive@jiveforum2.autodesk.com... > I have SP1 loaded and I refreshed my menus to see the Create ROW command under Parcels. However, the command asks for the selection of Parcels and everything I select says it was filtered out, whether parcel objects, alignment objects, polylines, etc. What am I doing wrong, or is this feature working yet?
    *Daniel Philbrick
    04-14-2004 09:10 PM in reply to: DannyCounts
    Danny, The ROW command in the Preview release is static. It creates parcel lines relative the centerline. If you move the Centerline after the ROW is created you will need to delete the ROW lines on each side of the centerline. Then run the command again. Note - having the ROW respond to changes in the centerline (ie, dynamic) is currently listed as a high priority requirement. Dan P "Tyler Townes" wrote in message news:407db2fd$1_3@newsprd01... > Danny, > > I was able to select parcels by selecting the parcel description text (lot#, > acreage...). I am, however, not quite sure exactly how it works. It does > create ROW, but when the alignment is moved the parcels do not update. > > Tyler Townes > > "DannyCounts" wrote in message > news:20467009.1081877968218.JavaMail.jive@jiveforum2.autodesk.com... > > I have SP1 loaded and I refreshed my menus to see the Create ROW command > under Parcels. However, the command asks for the selection of Parcels and > everything I select says it was filtered out, whether parcel objects, > alignment objects, polylines, etc. What am I doing wrong, or is this feature > working yet? > >
