• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    Distinguished Mentor
    Re: Intersections
    05-19-2012 03:33 AM in reply to: Joe-Bouza
    I was having this issue recently myself.
    I ended up removing the profile curves from the main road and the side road from anywhere within the intersection and only had tangents with no curves in my profile.
    I was then able to run the wizard successfully.
    I then put my profile curves back in after the intersection was created.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: Intersections
    05-19-2012 07:24 AM in reply to: andrewpuller3811
    I have no curves?
    I opened an SR. I'm sure my order of operations is flawed.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    johnm
    Re: Intersections
    05-19-2012 08:23 AM in reply to: Joe-Bouza
    Send me the file if you want. I'd love to take a peak under the hood.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    Joe-Bouza
    Re: Intersections
    05-19-2012 11:21 AM in reply to: johnm
    Thanks. I'll getcha on Monday....
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    Joe-Bouza
    Re: Intersections
    05-24-2012 12:26 PM in reply to: andrewpuller3811
    I got my SR response: evidently the intersection tool gets confused if the design alignments have more than 1 layout profile in them. I got rid of extraneous layput profiles and everything went according to hoyle
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    johnm
    Re: Intersections
    05-24-2012 12:29 PM in reply to: Joe-Bouza
    Horah!
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    Re: Intersections
    05-24-2012 02:50 PM in reply to: Joe-Bouza
    Aahhh. I recall that I had multiple profiles on one of my alignments also.
    Did not realise that would have been the cause of the error.
    Thanks for posting the solution.
    Andrew Puller
    Civil 3d 2013 64bit
    *Expert Elite*
    Joe-Bouza
    Re: Intersections
    05-24-2012 03:46 PM in reply to: andrewpuller3811
    UBETCHA
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    New Member
    Re: Intersections
    02-06-2013 03:22 PM in reply to: Joe-Bouza
    Either i'm missing something, or it's just been a long day of corridors. What's the solution to get away from this error?
    *Expert Elite*
    Joe-Bouza
    Re: Intersections
    02-06-2013 04:21 PM in reply to: kennedyhuynh
    I see your confusion kenny; I tagged my own solution and grabbed the wrong thread.
    According to tech support the intersection wizard will work better if there is only one layout profile per alignment. So ya gotta clean up the trash prior to using the intersection wizard.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
