• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Integrating structures into Civil 3D
    197 Views, 2 Replies
    11-16-2011 02:12 AM
    Hi guys
    I am creating a drainange drawing with Civil 3D.  first of all, I was wondering about headwalls.  I have a few winged headwalls I need to integrate into my pipe network.  Reading about, it says that Civil 3D 2012 has winged headwalls as part of the structures library in the pipe network section, but I cannot find them, only rectangular headwalls.  I also have a custom size headwall we have designed, how would I put that in, would I just model it up as a 3D solid in autoCAD, and then how would I paste it into my final surface model?  Also, We have basins at the end of our drainage ditches, which is basically a square basin made up of gabion baskets, again, will I create it as a 3D solid in autocad?  Hope this all makes sense :smileytongue:
    Martin
    Please use plain text.
    *Pro
    Re: Integrating structures into Civil 3D
    11-16-2011 05:38 AM in reply to: bigmaz
    if all you need to see is contours draw correctly to show a 2d top down view, then 3d solids are not necessary and a waste of time.
    a couple break lines strategically placed is all you need to get the job done with a winged headwall.   it's similar to constructing a retaining wall with two break lines.   One for ground at  top of wall and one for ground at bottom of wall.
    the contours don't care if a retaining wall is above the ground by a foot or 10 feet.
    gabion baskets are below ground, so only the top of them needs to be modeled for surface contours.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    11-16-2011 05:57 AM in reply to: dgordon
    Great, thanks for your help :smileyhappy:
