• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Inserting Excel Tables into Autocad Civil 3D 2013
    1318 Views, 9 Replies
    10-14-2012 08:17 AM
    Has anyone tried to insert Excel tables into 2013 3D?  It worked fine in 2012 but we just upgraded to 2013 and it no longer works.  We get an error message that Excel is not supported.  Is this a new feature or a bug?  Also, our old drawings with the table already inserted does not plot normally.  The table characters print at diffent sizes.
    Please use plain text.
    *Expert Elite*
    BrianHailey
    Re: Inserting Excel Tables into Autocad Civil 3D 2013
    10-14-2012 09:12 AM in reply to: jfletter
    What method are you using to insert the table?
    *Expert Elite*
    Joe-Bouza
    10-14-2012 01:27 PM in reply to: BrianHailey
    Hi Brian, Is OLE or Data linking no longer supported?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    10-14-2012 03:43 PM in reply to: jfletter
    Can yo post what version of Excel, or even better post the Excel file so we can test it?
    Bruce Klug
    AutoCAD Expert Elite
    AutoCAD Civil 3D 2013 Certified Professional
    C3D 2013 (SP1) (HF 3.0)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    *Expert Elite*
    Joe-Bouza
    10-14-2012 04:33 PM in reply to: klugb
    Hi Bruce
    I'm guessing you have not seen any anomolies
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    10-14-2012 05:22 PM in reply to: Joe-Bouza
    I wouldn't say that, but I don't get any error messages.
    I have had issues with not everthing coming over when I mess with the font size.
    Excel 2010.
    Bruce Klug
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    Valued Mentor
    LisaPohlmeyer
    10-15-2012 05:50 AM in reply to: jfletter
    I'm using MS Excel 2010, I copy the spreadsheet range, use Paste Special, paste it as an Excel link, no problem.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Active Member
    11-20-2012 09:21 AM in reply to: LisaPohlmeyer
    I'm having issues also.
    I'm using MS Excel 2007.  Sometimes my drawing opens up and states that the OLE link is broken and somehow reverts the Excel file back to the previous state before it was modified.  Very frustrating!
    It also only plots the OLE object 50% of the time.  I tried it with different printers, plotters, and even the same thing plotting to PDF.  Fixing to have to give up on the OLE technique.
    David Schuler
    Polywell Workstation
    Intel Core i5-2400 @ 3.10 GHz
    8 GB Ram
    64 Bit Win7 OS
    NVIDA GeForce GTS 450
    Civil 3D 2013, SP1
    *Expert Elite*
    Neilw
    11-20-2012 09:25 AM in reply to: jfletter
    Have you considered using a table object with the Data Link option?
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Valued Mentor
    TerryDotson
    11-20-2012 04:50 PM in reply to: Neilw
    That is a much better approach than OLE, but if your spreadsheet isn't simple it can make a mess.
    http://www.dotsoft.com/files/xl2cad-vs-tables.gif
