• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Accepted Solution
    In Civil 3D 2012 - Style Edit > Display Tab... Can not collapse layer column?
    194 Views, 6 Replies
    02-12-2013 01:02 PM
    In Civil 3D 2012
    See attached image.
    This is happening on any object style that I try to edit.
    In 2011 and 2013 it displays correctly on the same machine.
    Any thoughts?
    Jonathan Stewart
    CADvisers
    P.O. Box 7811
    Lancaster, PA 17604
    Ph. 717-468-3111
    Please use plain text.
    Active Contributor
    Re: In Civil 3D 2012 - Style Edit > Display Tab... Can not collapse layer co
    02-12-2013 01:58 PM in reply to: CADvisers
    Wow, that's horrible.  I'm assuming if you move the slider bar all the way to the right you still don't find the end of the Layer column?
    Valued Contributor
    02-12-2013 02:01 PM in reply to: brian.strandberg
    I do see the end.  And it does display the rest of the columns, but can't slide the column back to normal size.
    Jonathan Stewart
    CADvisers
    P.O. Box 7811
    Lancaster, PA 17604
    Ph. 717-468-3111
    Valued Contributor
    johngordon6189
    02-13-2013 12:27 PM in reply to: CADvisers
    when you slid to the end of the view and saw the other end of the header, did you try double clicking the line to pop it back?
    Valued Contributor
    02-13-2013 12:40 PM in reply to: johngordon6189
    Yes,  I tried.
    It works fine on the Compnent Type and Visible columns, but the rest are locked down and way, way at the end.
    I've tried right-clicking on the column headers, doubleclicking, and sliding.  Nothing!
    Jonathan Stewart
    CADvisers
    P.O. Box 7811
    Lancaster, PA 17604
    Ph. 717-468-3111
    Distinguished Mentor
    02-13-2013 06:54 PM in reply to: CADvisers
    The 2012 profile style dialogue settings for the columns are stored in the registry here -
    [HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A000:409\Profiles\<<C3D_ANZ>>\Dialogs\AeccUiPpVbStyleDisplayProps\ColumnInfo]
    replace <<C3D_ANZ>> with your active profile name.
    The key AeccUiPpVbStyleDisplayProps:CListCtrl::1864 stores the values for the columns widths.
    On my machine if I set the value to for the key to "0:1:" the column widths reset to the default widths.
    If you can access the registry and set the value as above, this may fix your problem.
    Of course the usual warnings about backing up the registry apply, etc.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    Valued Contributor
    02-13-2013 07:07 PM in reply to: andrewpuller3811
    Thank you so very much Andrew!
    Jonathan Stewart
    CADvisers
    P.O. Box 7811
    Lancaster, PA 17604
    Ph. 717-468-3111
